How far out of whack is the corner? And is it acute or obtuse?Oldman":wl4p9r85 said:That run is around 2.5mtrs and so is the other side over the sink area, so my idea was to fit the sink side worktop in place, cut the female joint on that in the corner where the drills are laying, then cut the male on a full length of worktop so I get to have several tries if I get it wrong (corner not square) and once Im happy with the joint I will cut off the other end and refit the tall unit.
Mine was out more than that. I thought about compensating by varying the mitre angle but it did my head in trying to work out how much to compensate to get the right fit. In the end I didn't bother and just cut it at 90 degrees then scribed the worktop for an even overhang at the front.Oldman":3kj4rdga said:Thanks for the link Paul, looks easy there.
Trim the corner is acute, looks like about 10-15mm runout in 2.5mtrs.
I have read that you can cut the male side of the mitre at up to 1.5 deg out of square and still have it mate up nicely, I am going to give this a try as with all the trouble I had getting plaster on the walls I really dont want to have to go chopping it off again
Oldman":n5nndftp said:The sink may cause me some grief though as it bridges across from a 600 unit to over a dishwasher, so even if I remove the dishwasher I am going to have to be inventive to cut the lengthways slots as they pass over the end side of the 600 unit.
I have been warned not to try cutting the long slot out on workbenches as the very small amount of worktop left front and back of the cuts will cause the worktop to snap when moved back to its units.
That's always been the case with chipboard. The main ingredient is old pallets that are shredded, complete with nails and any grit/dirt on them.Oldman":p2erduoe said:I am told it seems there has been a shortage of suitable material for making chipboard and old windowframes complete with bits of nail and solids like oak have been used.
I read that too but it didn't turn out to be that bad; just need to be a bit sensible when lifting after cutting out the hole.Oldman":p2erduoe said:I have been warned not to try cutting the long slot out on workbenches as the very small amount of worktop left front and back of the cuts will cause the worktop to snap when moved back to its units.
