Hi all,
Does anyone have experience with this Birch plywood supplier?
18mm Birch Throughout Plywood B/BB 2440mm x 1220mm (8' x 4')
I'm planning to build a closet with plywood faces and exposed edges and I was wondering if this is good enough?
I've never bought plywood before, if I go and visit this supplier, is there any specific things I should be looking for to make sure it's good quality?
'Birch throughout' means that it's 'furniture grade' and doesn't have lower grade plies such as poplar, with voids. Cheaper lower grade plywood as mostly stocked by DIY stores is construction grade, used for flooring, shuttering and the like. Such plywood may have birch surface ply, but the other plies are thicker.
Here's what the specification for the plywood at your link states:
Quote:
Birch Throughout Plywood is made from birch veneers, glued and
laid up in alternating directions to the required thickness. It thus provides a superbly consistent strong panel with known engineering characteristics.
The board is a B grade which means a higher quality finish and cleaner appearance. At the same time
the aesthetically pleasing, fine tight grain of the BB face is suitable for all types of surface finish ( or none ) as required. Please be advised that some suppliers offer a Birch-faced product made up of alternating veneers of other species – sometimes known as twin ply – this will not have the same consistent strength/engineering characteristics, stability or longevity of our Birch throughout product.
Grading Information
This product is graded B/BB. The B face is smooth and uniform with attractive light colour giving an elegant finish. The BB grade is most commonly used in applications where aesthetics aren't a priority. A BB face may have small knots and imperfections that may require slight repairs. It should also be noted that, due to the wood's natural properties, slight colour variations may occur.
Unquote.
So the 'B' grade side could simply be varnished/stained and wouldn't have imperfections. The BB side would have small imperfections, usually with small circles or ovals cut out of the veneer where knots have been, and a piece of birch veneer glued in, but as the spec says, still 'aesthetically pleasing'.
I've attached an enlarged the picture of the plies from the website and it's clear that there are 13 plies.
In short, that plywood is about as good as it gets, hence, the price.
Hope that helps.
Good luck with your project.
David.
