Budget Biscuit Jointer.
Petey83
19 Mar 2014
Enfield
Contemplating dipping into the world of biscuit joining as planning on making some MDF wardrobes.
Not flush with cash as have been on a tool buying rampage in the last month so after a solid budget option that will do the job well and last a few years of weekend use.
Any ideas?
Having owned a wickes biscuit jointer for a while and now have a Makita one the Makita one is much better.
But
The wickes one was perfectly useable but I did need to buy a better blade. The original one was too thin for most biscuits.
Mick
First post here ..
I have a Freud JS102 , for about 10 years - it was cheap - it works , things to note:
-blade , mine is fine - but a cheap blade may kick as you plunge it , plunge slowly .
- fence - rubber buffers help to keep the fence where you placed it - plastic ones could slip
- they are very simple machines , basically an angle grinder with a fence - cheap may be as noisy as cheap angle grinder
- research how to use one - there are plenty of online guides , practice making a small box to get the feel of it
you really need a decent flat surface to use one , you can use the stock you are jointing on the floor as a guide once you understand the biscuit game.
what about a biscuit cutter for a router? cheaper and probably better than a cheap jointer, if you already have a router.
+ 1 you can do a lot with it such as grooving, most things a biscuit jointer will do and it will be much cheaper
hmmm.... I do have a 1/4 router - Makita RT 0700. Had looked at the trend router bit but was unsure how good it would be.
May get one and try it out and wait and see if a Trend T20 or simular comes up at a good price at some point down the road
