brianhabby
Here are some pics of my home made air filter which was inspired by this one by DaveL. It uses the filters from this Axminster one.
It is basically a long plywood box that houses the main filter, it has an extractor fan at one end and the pre-filter at the opposite end. fairly simple to make. My extractor fan is quite a large powerful one but I don't think you need a very strong one. In fact I only ever have mine turned to the low setting as I believe if the fan is set too high, there is a risk of the dust being pulled right through. It just happens to be what was available at the time.
Sorry I didn't take any pics while I was building it but what follows should be self explanatory.
The fist couple of pics are just general shots.
This shows the pre-filter end, I doubt you can see in the picture but this gets pretty clogged with dust but is simple to clean with the shop vac.
With the cover and pre-filter removed you can see the main filter inside.
The box with the main filter removed.
The main filter separate from the unit.
The pre-filter and frame for holding it in place.
I hope the above together with DaveL's post inspires others to build one of these very useful devices.
regards
Brian
regards
Brian
