Today is going from bad to worse.
Just had a delivery of some rough sawn planks and have only just noticed they have delivered one less than they should of, or that I ordered.
It has then dawned on me that I have not ordered enough wood.
I have sat down trying to work out how much more wood I need but for the life of me cannot seem to fathom it out. I have worked out I need at the maximum 200 planks and the least being I have 1 plank too many. i have also calculated the amounts to many numbers in-between those :shock:
Would one of you be kind enough and let me know how many planks I will need in total.
It is 3x1 / 75mm x 25mm and it comes in 4m lengths
I need to cut it into 325mm lengths for palings.
Each will be spaced 25mm.
Total length required is 21m.
I also need some 2x1 for the rails that is easy to work out. I will need 42m of that.
Today I had delivered 27m of 2 x 1 so i need another 3 x 5m lengths to complete order
Also 5 x 4m lengths of the 3 x 1 (75mm x 25mm )
This job was originally going to go around some pampass grasses in the centre of our front lawn,but because of a major miscalculation I am now also going to have to do around 2 edges of the lawn. :roll:
