Boys school project
Hudson Carpentry
4 Nov 2010
Nottingham, UK
For them that saw my sketch up thread which had a helicar drawing for a school project, i thought you may like to see the outcome.
The boy is 8.
The brief was to invent a new vehicle that solves a problem. The model can be made of anything with no size limitations. Big mistake where im concerned.
We decided that a car that can fly like a helicopter would solve waiting in traffic.
Here is the sketch up again.
We hand loads of plans, using car parts to make working lights and moving blades. We also wanted it to steer but family let us down big time and didn't have time get the parts and make it all work.
First we made the front wheel.
We used 18mm ply laminated to make 2x 36mm boards that will hold a caravan jockey wheel. It was assembled using M10 threaded bar, washers and nuts. The wheel was designed to fit onto a 20mm axle, so for it to work correctly i turned some oak down to 20mm and drilled a 10mm down the centre.
We then used MDF (as thats what i had laying around) to make the two propellers.
We routed the ends over and cut a taper to try get close to what they look like. I then used the SCMS to create half lap joints for the 2 blades to meet.
We then set about the rare wheel assembly.
We used some softwood i had spare to joint two pieces together to make a centre support of the rare axle. We made a small dado down the centre on both planks so the bar would sit in nicely. Finished off with 2 pieces of joist to attach the assembly to the cars base. You can see one of the oak bushes in the picture where the boy is putting the wheel on.
We then set about cutting and assembling the cars body.
We used 2x2 to create some more strengh in the structure as just screwing the 18mm ply into 18mm ply ends wouldn't stand to long with 20 kids jumping in and out. We routed out some flutes on the front panel to be a grill & attached the door on with a piano hinge.
As the car was only just short of getting out of standard doors and a little over 1.5m in length we needed a way for some of the parts to disassemble.
So after making the tale with some laminated ply we used a sliding dovetail to enable the rear assemblely to be removed.
The socket was made from some softwood and re-enforced with screws down the sides.
We now turned out attention to the top blades and how to enable them be removed and operated from inside the cab.
We cam up with a prop. Using some 2x2 we cut a tennon one end and turned the other end round. Drilled a hole in the top the side of the round part of the prop an cut a mortise in the blades to accept the tenon on the prop. this enabled the assembley to lift out of the top to get it through doors, plus while in the cab you could turn the blades using the prop.
More to come (at my max file uploads)
    32 KB
    115.8 KB
    111.3 KB
    115 KB
    123.1 KB
    118.8 KB
    93.1 KB
    104.1 KB
    154.9 KB
For the insides
We built a seat using 18mm ply and some 2x2. The steering wheel was basic now as we wasn't having the front wheel turnable. We used some 2x2 and drilled a 10mm hole down the centre, meeting this channel i drilled a hole for a nut to slip in keeping some threaded bar fixed to the 2x2. We cut some more laminated 18mm ply on the bandsaw to a 10" diameter for the steering wheel, using some washers and a locking nut this did spin. In the above picture you can also see the lights. Originally we wanted some car post lights but opted for bicycle lights due to the man at the scrappers being a bit of an a**e. We just cut a hole for the to slip in.
The 8 year old choose an interesting colour scheme and we set about painting.
We also printed some number plates off, cut the letters out and stuck them on some card (to make it look more like a the kid was involved), laminated this and mounted it on some 6mm MDF. We also made some wing mirror with some old dowel and ply, these just slipped into holes so could be removed to get the large toy through normal sized doors.
The teachers loved it but im very sure once he trys to move it and realises every other kid brought in breakfast box models, he will specify a size limit next time :wink:
All in all Kid loved making the project. Obviously he didn't touch machines but played a part in making the project.
    106 KB
    92.4 KB
    128.8 KB
    140.1 KB
How cool is that! looks like you both had a lot of fun :D
never did stuff like that when I was at school :(
Me neither which is why i jumped at the chance to do something like this while the teachers was off guard.
Yeah we had fun, Im 6' and about 15-16 stone, got in it when the seat and steering wheel wasn't inside which shows how big it was. Let the boy push me around for abit :D Got up the workshop and back again, he was puffed out hehe.
We plan to get it back and continue work. Was thinking about making it weather proof and keeping it outside once we finish making the wheel turn with the steering wheel.
I can see some ******* moments in the pipeline! :lol:
You know I like seing things like that, a bit of fun and I am sure the young lad will never forget the time he had. It's those moments in life that you couldn't put a price on.
All the best.
