Right then here's my effort for the box jig.
Iv'e dowelled it to the sliding table so that it can be mounted in the exact position whenever I use it.
[/[URL=http://s3.photobucket.com/us...ms/y79/wyntog1/P6100025_zps1ipg4wat.jpg[/img]]
I did a few tests as I could see problems with what the blade kerf was relative to the carriage travel for one revolution of the handle.
Using a digital vernier this is what I found
For 2 revs 3.01 mm
4 revs 6.00 mm
6 revs 8.99 mm
8 revs 12.00 mm
10 revs 14.98 mm
12 revs 17.99 mm
I did this for 24 turns and was constant plus or minus .01 mm
the blade kerf is 3.00 mm.
First trials were a disaster. Couldn't get the spacing anywhere near correct.
I lined up the work piece touching the left hand side of the blade. I then did 4 turns of the handle making a cut each time. I then have to make 7 turns of the handle before making the next cut.
This gives me a 6 mm profile. It's ok on material above 9 mm but find a sloppy fit on anything less.
Hope this may be of use to anyone else making a jig :shock: :shock:
Alan.
Edit The screwed rod is 10 mm.
