For some reason I decided to challenge myself and turn a bowl from a Lignum Vitae bowls ball, and the aim for it to be as thin as possible and end grain . I never turn ‘straight forward’ bowls and very rarely with a flat top…
Well I suppose I failed really as in the attempt to make it thin I broke thru the side . I managed to turn the complete bowl with a wall thickness of about 1.5 mm and it weighs just 35 grams. ( just over an once) What I got wrong was the final clean up with Abranet. As it was end grain there is an area near the top between very hard annual rings that pulled away surprisingly easily. I decided to stick with it and ‘finish’ it , tho it will serve no useful purpose. Don’t think I can get away with calling the break thru areas ‘ a feature’
Haven’t turned anything for several years so at least it was good to sort out the lathe and have a go ….
