I am not sure about the heat kilns. There is a definate skill to drying different woods. The one problem that people have when learning to kiln dry is that it needs to dry a bit, then equalize, then dry and equalize, till done. If it isn't done correctly, if you rip a 2 inch thick board down the middle, it can spring outwards, cupping out from the center, or the ends peeling back, or twisting. There are ways to dry and releaving stress. The best kiln dried wood I have worked with was done in a vacuum kiln. It cooks at a much lower temp because, in a vacuum, water will boil at a lower temperature, and the vacuum can pull the water out. You rip a board on your table saw, and you get shavings, not dust. Much like air dried woods. I would love to experiment with a vacuum drying chamber for my bowls. Don't have the know how to do it though.
robo hippy
