heimlaga
Those of you that know me are surely aware of my habit of using ingenuity to compensate for poverty.
I got this ancient spindle moulder for 25 euros. The hole in the table is way too small for any kind of modern spindle moulder tooling and the spindle itself is one inch in diametre which is a rather obsolete size is Europe. It came with a pair of slotted collars for slip knives and that was clearly the only tooling it could ever take. The wooden machine frame is gone.
The intention is to convert this wreck into a super solid professional router table with the most luxuous router lift in Finland. Just unbolt the bearing blocks and install a 12mm mild steel plate with a mounting bracket for the router onto the mounts for the old bearing blocks using the old square head bolts.
Are there any suitable fixed base routers or router motors on the market for this purpose?
Disclaimer......please do not ever convert a spindle moulder to router table unless the hole in the table is too small to ever be usable with modern tooling. Old spindle moulders are great machines in their own right and there is a finite number in existance. Every usable castr iron spindle moulder that is destroyed is a loss for mankind.
