Dr Al
As per title, a Bosch GTS10XC Table Saw with all the bits and bobs it came with (including the manual) and a few extras for good measure.
These are £660 new (not including all the extra saw blades); I'm looking for £450 ovno (collected from Gloucestershire).
As you can see in the last photo above, the slide-locking screw for the mitre thingy has been replaced with a brass screw as the original was lost. The photo also shows an MDF "zero-clearance" insert. It's quite old and shabby but could be used as a template for a new one. The original insert is also included in the sale.
The fence has had the (arguably essential) upgrade to replace the guide pieces with larger 3D printed ones and to add a bearing on the back edge. I've still got the original parts if you want to revert for some strange reason:
Comes with a selection of different blades and various push sticks etc:
Optionally (but for free), also comes with my cross-cut sled (this is an old photo: the sled looks a bit shabbier now but still works as well). If you don't want it, I'll take it apart and use the plywood.
Also optionally, comes with my slightly unusual trolley, which was made to make it relatively straightforward to put it side-on into my shed. I'll completely understand if you don't want this (it is a bit special-purpose after all!) and if you don't, I'll take the castors off and take the rest to the tip!
Also listed on the MIG welding forum & on gumtree
