Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
It's one of these:
I am very fond of it, and it's probably my most used power tool by a country mile. But... after lending it to a neighbour, it returned with the chuck jammed wide open (everything else is fine).
I can't free up the chuck (yet!), I think because the scroll is damaged - it was the least good part of what is otherwise a very nice tool. I can and have easily removed the LH-thread Torx machine screw down the middle, but am really stumped as to how to remove the chuck presently. Ordinarily, I'd grip a large Allen key and give it a sharp tap with a hammer, but because the chuck is broken I cannot see an easy way to do this.
Questions:
1. The obvious: I think it's a right hand thread chuck-to-gearbox, so the LH machine screw locks everything in use. Does anyone know for sure what they usually are? I don't want to get heavy with it before knowing for certain.
2. I am going to be patient, and have Plus Gas to drip down the central hole, but does anyone have a nice trick to undoing these things (when you can't grip anything in the chuck, it seems!)?
Miles Tools, as ever, come up trumps with the right chuck in stock and at a reasonably sensible price. But I also have a spare chuck that might well fit, salvaged from an older Bosch drill, which I will experiment with, as it's better made than the present one (and probably the replacement too).
Of course, none of this applies if I can't get the damaged chuck off... so feel free to wade in with ideas.
Thanks all,
E.
PS: Worst case, bare drills are still available, just about, and fairly inexpensively. I don't want a hammer gearbox on this tool: part of the value of it is the compact size (lightweight & short length), so the current models are unattractive.
Questions:
Thanks all,
E.
