duncanh
looking in the archives it appears that I never posted the results of my strip laminated boomearng experiments from a couple of years ago, so here they are along with a couple of lapjoint boomerangs.
A strip laminated boomerang made from ash, makore veneer and iroko inserts.
The 5mm thick strips of ash were steamed in a homemade steam box for about 14 minutes, removed and then clamped around and mdf form. I left them for several days to set into shape before I glued them together with makore veneer and iroko wedges (which I'd also steamed to shape). The glue used was waterproof pva.
This gave a boomerang shape which was about 5cm thick, which I then sawed into 7mm thick slices on the bandsaw. These slices were then profiled using a combination of files, powerfile, cabinet scraper and sandpaper to give the airfoiled boomerang. After a few test throws and profile alterations I applied several coats of tung oil.
This one is 49cm from tip to tip but the others are 51cm as the tops level wasn't glued right to the end. Thickness is approx 6mm.
It has a 30-35m circular flight that climbs steadily and then has a nice hover for an easy catch.
A strip laminated boomerang made from oak and makore veneer.
The 5mm thick strips of oak were steamed in a homemade steam box (made from grey plastic drainpipe and a wallpaper steamer) for about 14 minutes, removed and then clamped around an mdf form. I left them for several days to set into shape before I glued them together with makore veneer.
Thickness is approx 6mm. The top one flies ok and is impressive in the air due to it's size and the very open shape it has whilst flying. It's possible to catch it but it's quite scary!
A lap joint boomerang made from iroko (from and old shool bench) with maple (I think) highlights at the joint.
The boomerang is about 6mm thick and has a wingspan of 39cm. It flies ok and goes about 25m, keeping low and with a fast return.
The lapjoint was made with a combination of hand tools and a dremel used as a router table.
Lap joint boomerang also made from iroko and maple. Doesn't fly brilliantly - probably due to too much drag from the holes left from where the bench top was attached to the base.
