I am having some difficulty with these
basically i have built the drawer boxes perfectly to size and cut the notches what i seem to be having is some difficulty with the hole at the back which receives the hook.
I opted out of buying the drilling jig and used blums measurements to mark and drill the 10mm deep 6mm wide hole. Whilst the drawers operate there is some degree of sag when the drawers are fully open, up to 3mm over the entire drawers (250mm slides) when they are fully open. this drooping drawer is obviously is not very ideal.
Basically whilst the hooks seem in line with the holes there isn’t really much grip at all so they are quite loose free in the holes causing the draw to sag slightly. i just can’t figure out where I’m going wrong.
one drawer the hook fits the hole quite snugly but the others i just can’t get it right. I have marked drilled and plugged with a dowel and predrilled three times now. tried shoving the drawer shut and using the indent of the hooks to drill the hole but to no avail.
I notice there is some adjustment on the back of the slides to move each slide up and down and thought that could be where I’m going wrong but couldn’t get it.
does anyone have any ideas?
thank you much for any advice you have.w
