pitch pine
I have been making a blanket box from some beautiful Parana Pine boards that came from a workshop clearance. I have built the body of the box and included a couple of hidden drawers (copying a Victorian blanket box I already have). The problem is the lid. I jointed up enough width from the boards I had and flattened it after gluing up. When I test fitted it and left it closed overnight the difference in humidity made it warp alot. If I leave it open it goes back to true. Will this movement be reduced by having a finish on the wood? Could I fit breadboard ends to minimise the movement? Thoughts please. The first picture shows the fit before it has been closed for 24 hours. Overnight it opens up over 1/2 inch.
