The max tension is just before it snaps with a bang and you jump across the workshop and hug the table saw!!
I've never had a blade snap, but have I read of many accounts of this.
Seems little information regarding folks actually describing their blade snapping in detail, but from what
little I can gather, it
seems like the snapped blade will try and exit the machine, in a linear fashion,
i.e in-line with the wheels and exit between the guides.
I wonder if I'm correct about thinking this is the likelyhood, should the blade not catch on the tires and gouge or cut them off.
This photo might suggest so
I wonder if these photos of a Canadian Luthier's Grant Goltz setup would be for the same reason,
or if it was just because of the huge billets.
A video exists somewhere I might try find.
Worth noting most of the Italian machines have fences which can be used either side.
