YorkshireMartin
Hi guys,
The stock in question has been acclimitising for 10 months inside the house in preparation for a piece of furniture. Moisture content would have been probably 15% when purchased and it was stored in a temp/humidity controlled warehouse. Highly reputable merchant.
It was 45mm thick and I've resawn it in half (tonight) on the bandsaw due to a design change.
Within an hour, each piece, which came off the bandsaw flat, has started to cup along the length of 1.2m. I have to be honest I've been a bit taken aback as walnut is known to be stable.
This was planed/thicknessed at least 10 months ago and I'd have thought it had ample time to dry gently. I understand resawing would allow the escape of more moisture by surface area, but still, we're talking 2mm off the straight edge in the center. Reminds me more of spruce/larch type stability problems.
Can someone explain what is going on here? I am a bit lost on this one.
Many thanks
Many thanks
