Bit of curved work
jasonB
26 Nov 2004
Surrey
As you can see I've been going round in circles this week
Been making these carcases and some standard square ones as well for a "?" shaped kitchen this week. The doors will be thermo formed Parapan in the bright blue shade.
The hardboard on the floor is the template taken from the room, the cross is the centre from which all the curves are swung and the sides and dividers radiate from.
There is a straight section that comes off from the left of the curve that will hasve base units for slim dishwasher, compact oven & induction hob, ice maker. Then a tall unit for fridge and bean to cup coffee machine.
BTW this is just the breakfast room
Jason
Now that looks like a right pipper to make !!!!
Hope you are to be handsomely rewarded by the client....
Karl
Waka":15wmoh1f said:
if thats just the breakfast room whats the kitchen like?
Blinking big :D
I'm only likely to be doing the carcases on this one(too much other work), it's through the Kitchen designer that I do some work for, she picked the job up as she was doing the kitchen in the new build house next door. They knocked down an older house that cost over £1.0m to build the new one and the kitchen is costing them over £100k :?
The house that this one is going into is even larger and built to a very high spec. Just to set the scene, if you were to stand with your back to the breakfast room sink (to right of internal draw unit) you would be looking through a 10ft high by 15ft wide glass wall with a frameless glass door that gives access to the indoor swimming pool with whirlpool beyond. This has a lot of blue glass mosaic so thats why the doors wiil be blue with a white (at present) Corian top. Above the center of the circular part of the room is a large round glass skylight and the floor is all white marble.
J
appropriate design really because it'd have me guessing! :?: :D
Riddle me this: Are the doors made to fit or standard sizes?
The doors are made to measure. Parapan have about a dozen standard radius moulds that they can bend the material over, luckily we can use a 900mm radius one for these doors with an average worktop width of 650mm. You can specify the length of the curve, in this case it worked out at 420mm on the face, they sent a sample for approval before commiting to making the doors.
If what you need does not suit they will make up a new former and charge you for it, they will then add this to their range of available profiles.
It can be worked in much the same way as solid surface materials and then polished up with something along the lines of Micro-mesh. They also do end panels and a 4mm thick version if you need it.
Jason
Jason,
It's going to look fabulous!
What's the joinery in the cabinets? I can see pocket hole screws in the end unit but presume it's biscuits or some such in the central ones.
Carcases are done with biscuits and carcase screws, the bit at the end is just to support an end panel and has a few pocket screws as well as the biscuits & carcase screws.
Jason
Execllent looking stuff. I imagine there will be a twitchy moment when the doors arrive wondering if they will actually fit :wink:
Please post finished pics
Tim
Looks fantastic
Is this going to be in a house in Oxshott by any chance?
Very impressive! :shock: I was about to ask where you got the shape from but, then I notice the sheet of hardboard on the floor. :roll:
I presume the top is made of several small segments, biscuit-jointed together? I can see you struggling to get that out of one 10' sheet, unless my eyes are lying to me.
Property is in the Kingston/Richmond area
The curved section is made up as three base units, you can see the double uprights, each 59degrees of the circle (I suspect the architect drew it at 180 deg for the curve but you know what bricklayers & plasterers are like :wink: ) I still only got a top, bottom and one shelf from an 8x4 plus lots of waste. Made a template from 9mm MDF, drew round it onto the MFC a bit oversize then cut the boards before using a multi-trim bit in the router to get it to final size.
Jason
kingston hill?
when i worked for a joinery in kston we did loads of work up there and oxshott.
by the way anyone from surrey no of any small workshops that might let out some benchspace?
Dave
