woodbloke
Finished the Big Woodie at long last as I had to wait for a while for the 10mm glass for the sole jig to arrive. First pic shows the mouth adjustment arrangement, a collection of bolts and studding held together with a few locking nuts:
and when it's in place, the mouth can be closed up really tight, even closer than shown in the pic below:
Here's a couple of shots of the finished plane:
It will cut but the blade needs a little more work doing to it as it's a bit on the blunt side, needs a good honing. In use, the plane is as I wanted it, as it has the length to edge joint long boards but not the unwieldy beast that normal jointers tend to be, in fact when it's picked up it feels quite 'dainty' which surprised me. Finish is a couple of coats of matt Osmo Poly-X with some teak wax over the top - Rob
