ajmoran
I needed a bedroom wardrobe to work around a chimney breast and here is the (almost) finished result. All 3000mm by 2230mm and 300Kg of it.
Full disclosure: the entire piece was designed with my Templates by numbers online system. Hopefully this will shed more light than the other thread on Templates by numbers.:?
The room has an awkward chimney breast, but rather than build units either side of it, I decided to cover it completely with a shallow cabinet. Here is the space during the cabinet install. Note the plinth to bring the cabinets to the same level. The newspaper taped around the floor is to stop any potential dust coming through where I'd removed the skirting board in this draughty 1950s house. A piece of wood is attached to the ceiling (and through to the joists) and the tops of the cabinets will be screwed into this. The cabinets are designed to stand just short of the coving so I didn't need to make a mess hacking plasterwork.
All the cabinet carcasses in place and testing the position of hanging rails. The shallow cabinet will be used for belts, lotions and potions etc.
The carcasses are 18mm Melamine faced MDF, the doors are 18mm Birch Ply and the backs are 8mm Birch Ply. The colour variation across the backs is extreme but I thought that makes for a nice surprise on opening the doors of each cabinet.
The drawer units are made up of comb jointed boxes with a false front applied (false front not attached yet). The comb joints are progressively sized to match the drawer heights.
The drawer box comb joints were cut on the bandsaw, using a template - of course
Some of these drawers are huge - 770mm wide, 387mm high and 470mm deep - a job for a quality runner. I used Blum Tandem with the TIP-ON option so it is push to open. I used TIP-ON on the doors as well so the whole unit is handle-less.
Pictures of the completed unit.
Andrew
Andrew
