Bi-metal Bandsaw blade woes
Ian
5 Apr 2007
Northern Ireland
I just got a 131" 3/4" 4TPI Bi-metal blade the other day and on cutting some old wood down I hit a bolt of some sort (very hard)
Didn't realise and kept pushing :cry: now the blade just barely cuts and no more.
Anything I can do to save it ?
cheers
Ian
cheers
Ian
allegdedly (according to an and bob phillips) you can resharpen a blade by using an abrasive disc on a sander and just touching the top of each tooth (with the saw off and rotating by hand obviously)
however for your degree of damage you probably need a saw doctor and it might work out cheaper just to replace the blade.
if you are going to do a lot of wood recycling you also ough to invest in a metal finder as bolts, screws, etc are a common occurence ( ive found rifle bullets, musket balls and allsorts in recycled oak beams)
cheers
Ian
I suspect the bolt might have been high tensile steel...an M42 blade (if that's what you're using) would probably struggle with that but I understand they cope very well with ordinary steel ie: nails - Rob
I think the best thing you can do to that,
is to cut it up and make a few thousand chatter tool tips :? :shock: :roll: :lol: :lol: :lol:
John. B
