D.Want
New member
Hi all,
First time post here. Apologies if this post is in the wrong location.
I’m looking to purchase ‘a’ spray gun for my 50L air compressor. It’ll be used for painting small metal projects build with mostly steel box section (25x25mm box) - first primed then top coat. I am aware spray painting is a complex art and there is large a range of spray guns to choose from- HVLP, LVLP etc.
Considering I’m not looking for wide fan coverage (as it’s only box section) and my metal projects are mostly small furniture pieces, do you have any advice for what type of spray gun would be most suitable? I’m looking to keep the budget on the lower end if possible. Are the cheap spray guns often included in the ‘3/5-piece starter bundles’ with hobby air compressors acceptable for this application? I should also add, I’m not looking for a car body panel finish, just a general metal paint finish.
Any advice would be much appreciated.
Thanks.
Thanks.
