Wrongfoot
The sash windows and sills on the front (S face) of my house are showing largish shrinkage cracks, mostly with the sills shrinking away from the windows. I need to fill them and repaint. They're not original, but a 10-15yr old modern double glazed wood window, reasonable quality, softwood with a modern white paint finish, but no doubt bodged in with silicone and rawlplugs somewhat by the usual "do it in a day window fitters" used to fitting UPVC in a hurry. Everest ripped off the previous owners trading on past glories and providing an ok product at a luxury price.
Can't justify removal and replacement or would prefer not to replace the sills, The wood isn't rotten or fragile yet it's just behaving like a softwood does as it weathers and dries, cracks from 5-10mm between sill trim etc. and few end grain splits to fill before painting too. A a winter with those cracks letting water in will likely damage them so I need to get them maintained.
What filler / caulk would you recommend? Anything I should avoid? Should I shim in some timber strips into the cracks? Hoping for an effective but quick fix as I've a lot on but don't want to be doing it again next year. Hope you all don't mind offering some advice.
