Hi Kym
I totaly agree with what you have said and thankyou for the good advice, you may be correct when you say that the problem could be teknique although i do employ all the things that you have recommended.
That is why i asked the question, yes i do use 80 grit and follow through the grades sometimes down to 600 grit, but using the abronet i still seem to get scratches show through. I am not trying to say that i am not at fault and obviously you get along with it, but it does seem that i am not alone in my thoughts about abronet as a couple of other posts have said that they have or are going to stop using it.
It would be interesting to see if there is anyone out there that wants to champion it, it is not that i think that it is a bad product on the contrary i am sure that it has its place in woodwork/decorating and so forth, i just don't see it as quite up to the job for turning.
Regards
Berns
Regards
Berns
