h.g.
I am looking for curved panels with a radius of 150 mm and the stiffness of flat 18 mm plywood sheets. 1.5 mm 3 ply aircraft plywood looks good but is too expensive. 3 mm 3 ply marine plywood is just about affordable but is the radius too small? Table 1-2 on page 1-25 [of an old aeroplane manual I do not have permission to link to] suggests "thoroughly soaked in hot water" would work whereas 10% moisture would not. So the radius looks to be close to the limit. Does anyone have good or bad experiences of soaking plywood to make tight radii?
