Tasky":2gvhvzni said:You keep your vice properly lubed and everything, right?
I'm not sure that's necessarily the case. It's certainly nothing to concern oneself with, regardless if the vice is quite old. In the normal course of events the lifespan of vices can stretch to more than a century even with heavy, sustained use.Tasky":2s8wxxtl said:I imagine there comes a point where the cast iron will eventually crack?
I mean regarding Mike's remark on abusing them as much as you like... I'm sure it's possible to eventually overtighten a vice and break something, no?ED65":gsxcs03e said:I'm not sure that's necessarily the case. It's certainly nothing to concern oneself with, regardless if the vice is quite old.
Bm101":39tf8rhk said:Constantly racking a vice with over large faces fitted might affect it over a suitably long time possibly?
Would you not crack the cast iron main body first?Bm101":3ayuoofs said:I think you'd generally always bend the handle before you bork the thread
Yeah, we're into the realms of theory again - Cue argument thread about how much pressure you should tighten your vice to when holding workpieces!MusicMan":3ayuoofs said:I don't think the OP need worry in the least, at tightnesses comparable to usual clamping pressure.
