Gringo El Bingo
New member
Hi all.
First post here, so apologies if I’m in the wrong section etc.
I’m looking for some advice about buying a table saw. I think I want a bench top saw, which I can build into a bespoke bench to fit my unusually sized workshop.
I only have a budget of a few hundred pounds, and have been eyeing the Axminster TS200. I like the fact that I can buy a bigger (wider?) fence for when I build it into a bigger table. I also like the fact that it has a cast iron top.
My question is, is there a cheaper alternative? They seem to be going on eBay for nearly what they cost new.
Bearing in mind I plan to build a mobile bench around it, so will want a wider fence width (?), are there other saws worth looking at? I’m quite happy buying used.
I’m a hobby furniture maker, so it won’t be getting masses of use, but I fancy upgrading from the track saw/ jigsaw set up I’m using now.
Many thanks in advance for your help,
