DannyEssex
Hi guys
Sorry if this is in the wrong section, but I have a question about my shop conditions and a bench build.
My "workshop" is basically a 10x8 shed. It has no insulation and I know this is a top priority to get done. But I really want to get started making stuff first and I need a bench to work on so have decided to build a bench as my first project.
Now my worry is after reading up on here loads is that I have read people to advise that when you buy the timber, leave it to settle in its conditions its going to be staying in before working on it.
My plan is to use Wickes or my local timber yard for my timber and if I can I will get them cut the majority to size for me so I can fit it in my car. I am going to be using Wickes planed redwood, 4x2 PSE. I am planning on following Graham's build on his blog here http://gshaydon.co.uk/blog/the-workbench-build-begins
So will be using Tenon and mortice joints etc
So should I leave the cut material to settle for a bit before I start my build or can I get started right away?
If I build the bench in the winter will the summer conditions affect the joints and vice versa?
Or am I worrying to much and should just get on with it
Hope all that makes sense and thanks for any help and advice
Danny
Danny
