Bed extension for Jet 1015?
Jorica
23 Jan 2025
Leicester
Hi there,
First post, so bear with me!
I'm looking at getting my first lathe (second-hand Jet 1015 for ~£150. I'm concerned it will be just 2-3 inches short for the projects in mind. A quick Google search gives hope that I could get a bed extender but I'm seeing some conflicting prices and a lack of dimensions.
Can anyone tell me if this would fit the Jet 1015?
https://www.axminstertools.com/axmi...utm_content=2266&tagrid=69707390&glCountry=GB
Thank you.
    79.1 KB
    74.9 KB
    175.8 KB
If you have not yet purchased a lathe and you are worried it will not be big enough I would suggest getting a bigger lathe from the start! it would be very frustrating if you spent your money on a machine then need to replace it. There are plenty of turners on this forum that can give you good advice.
Well I'm torn between the Jet 1015 and a Record DML 24x. The Jet 1015 has a larger turning circumference (but shorter bed) whereas the DML has a longer bed (but smaller turning circumference).
I  think the 1015 would be long enough, but I'd feel more comfortable knowing I could extend it if I needed to.
