It’s funny knife forums think the people who do the plane tests are crazy and seemingly vice versa
XHP is effectively a stainless D2. Being PM it’ll be finer than D2, but if hardness matters more than grain size, and rust resistance isn’t needed, why not just go for D2?
Especially if you aren’t doing any controlled heating or cryo.
D2's failure size (bits that come out) are greater than the difference in optimized carbon steel vs. slightly less great by a factor of 10. It really comes out in large bits. XHP can be chipped, but it wears really uniformly.
I think knife people can't comprehend why heavy hand tool users really value the fine edge staying in tact (they would refer to that as edge stability I guess) and sharpening and grinding being easy, and especially, that we don't swing our tools anywhere and use them like levers. We swing the hammers into them, but holding the tool straight up and down and swinging the hammer into it is far far easier on edges than swinging a tool.
XHP also has much better wear resistance than D2 (I guess due to the enormous amount of chromium in it). When I tested irons (My xhp vs. my O1 iron was 1.85, and LV's was about 2, but that was my first iron and it was a tad soft. Just one cycle to dulling for my xhp mule vs. O1 was 6300 feet of planing in beech, so I didn't test unlimited combinations. My subsequent iron was a tad harder, so the number would probably be more like 2 to 1 in clean wood vs. O1. PM V11 in two tests achieved about two to 1 vs. O1.
I believe D2 in brent beach's test wore only slightly better than A2, or about the same, but the bevel was very ragged. Why this is, I don't know. If the hardness is lower, that could explain some.
https://brentbeach.ca/Sharpen/bladetest.html
If you look at the pictures, though, you can see how ragged. It seems like knives are kind of divided into two camps - the microstructure forgers, and then the modern steel sand cutters. I don't know how much the microstructure matters with S90V, because its grace is that it can cut a lot of sand. A whole lot. M4 can cut a fair amount of sand and if it's CPM, it has good edge stability (but it's expensive and can't be tempered easily by an average guy).
I temper in my kitchen oven on convection in a specific spot with a hanging thermometer for a second temp check - I could reasonably go 450. Most of the high vanadium steels have super high tempering temperatures and will air harden if ground red. Not sure where D2 is, but would expect it's tempering schedule (based on the alloy) to be not that different from carbon steels.
At any rate, the answer about XHP is in 1) I know what it is and I have a reliable method to harden it without damaging the fineness, and 2) it wears very uniformly as long as it doesn't encounter difficult cutting. It actually leaves a brighter surface behind than carbon steel when sharpened on the same stone. And the huge amount of chromium seems to make the cutting resistance less. I found this resistance oddity both in testing chisels at same angles, as well as smooth planing. For some reason, CPM 3V and especially CPM M4 create a lot more resistance with the tip of the iron passing through wood and the shaving flowing over the flat side of the iron. It's uncanny - I may not have noticed using one singly, but I was rotating irons every 200 feet and the feel was stark - so much that I thought in my first test that maybe I didn't sharpen 3V well enough (despite looking at the edge end to end under a microscope).
I'll give you a couple of pictures in a separate post so you can view the uniformity of A2 vs. an O1 iron that I made. These are the ratios that I found, though (off of the top of my head, if O1 at about 63 hardness gets a 1.0)
O1 - 1.0
A2 - 1.25 (but miserable to use in the last .25, so it's pointless vs. good O1 at same hardness)
China HSS (65-66 hardness despite the listing claiming 61 - alloy close to M2 by XRF but slightly short in some elements) - 1.6
Japanese blue steel - 1.0 (strange carbide release - seems like without that, it could've matched A2 with better uniformity)
3V - 1.6 (59 hardness - the person who owns that iron sent it to Bos for heat treating before Paul retired requesting 61 hardness, but the spec is 59 and they ended up making some of the order that that guy had 59 instead. A shame, as abrasive wear is improved 20% by adding those two c-scale points - and this is another reason why I like to harden and temper myself - I will never have a 2 point spread in a finished iron. The flip side is that for something like 52100, if you were willing to forge it, a commercial heat treat service can temperature cycle it properly and really finish the job off better for you, so you could cut nails better with it without breaking it).
V11 - if it's not XHP, it's XHP's doppelganger - 2.0
M4 - 2.05
What did we learn when doing the testing? (none of the above steels are really coarse like D2, so all of them left an acceptable surface. A2's surface went crappy at the 1.0 point. I've tested A2 before. It always seems to shed its edge in the last 20% of a wear cycle - no clue why, but I"ve seen it in more than one A2 iron, and in more than one brand. 3V, M4, V11 and O1 all had lovely uniform wear.
I don't own the 3V and M4 irons, so they went back. V11 is my choice on clean wood in a contest like this, the combination of factors is nice, and it's probably still cheap compared to M4 and high vandium irons (which take a long time to final size/finish after quench and temper) . Since V11 will lose some of this advantage in rough sawn wood and in dimensioning, it'd be nice to know if the same is true with M4 and 3V, but there's no advantage to finding out as there's probably no way to get a good iron made from good steel with proper heat treatment in either for less than $100, and the wire edge on 59 hardness 3v is NASTY. You can create a persistent wire edge that doesn't strop off easily off of a fine finish stone, or even 1 micron diamonds on cast iron. Sharpening on oilstones is out of the question. V11 finishes nicely on oilstones.
O1 is still the champ for all around work. It's easier to refresh if it does get damage and the damage seems less persistent in an edge (you don't come back after a sharpening cycle and find some still there). You really have to bear down on the others to grind through all of the damage, even when it's only a few thousandth's worth.
Going even simpler (ward, water hardening), sometimes a ward iron won't even take damage in the same thing that nicks all of the above. It has very little abrasive resistance, but the knife people would say it has excellent edge stability. A ward iron lasts about 75-80% of O1.
Alloying and wear-related elements in plane irons, and suitable hardness are more important than forging and refinement, and the excellent edge stability of O1 is available to anyone as long as the stock is good quality and the iron is made through the grain length and not across it.
