having a play with the lathe (Record Power 0 ) and had a catch then a noisy bearing started soon after.
managed to get the drive shaft and bearings out (after there were 2 screw to remove with the allen key, came out easily then!)
the big bearing that appears to have failed is the big one (NIN 6204z) but wondering if it is worth getting a new one for the other side while i am here. it is quite 'grindy' but when spinning makes a racket.
Also any preferred types to buy, or is it possible to regrease them? the lathe is quite old so likely they may be servicable?
thanks.
thanks.
