RogerS
When we moved into our house 20 years ago, the first bathroom that we did was done on a bit of a budget. It's an old house - the part I'm working in is about 300 years old or so. A rural property that was part of a farm means that bodging was the order of the day. Over the years the building has sagged especially the floor in the bathroom.
To get round this, at some time in the past 50 years or so, the owner built up from the old original floor and laid more floorboards on top of the original boards but these have also suffered the ravages of time and have shrunk in width and parts are held together by the woodworm holding hands.
My builder bodged the fitting of the wash-basin and WC and over time the wall has moved, cracked and basically looked unsound. So over supper one night SWMBO said 'As we've got the plasterer coming in downstairs, why don't we redo that wall? And it would be nice to replace those old floorboards with new oak to match in with the rest of upstairs. And I'd like to fit a shower to one end of the bath. And if we're doing that then we ought to extend the oak through to my study'.
In retrospect, the wall was the easy part even though it took two days to rip out all the old grotty stuff, go back to the original brickwork - I did say that this part was timbered, didn't I? - and then make good with many layers of plasterboard and ply for the washbasin and WC to be fixed securely.
So now I am starting to do the flooring.
Plan A - was to remove the second lot of flooring and simply relay the new stuff down onto the old original boards. Thank God for the Fein. I was able to cut the boards flush with the wall all the way round.
Having removed the floorboards, this is what I'm faced with.
What doesn't come across is that the far corner on the right sags by 1". Those original boards are 19" wide - I think that they were called coffin boards - Thank god, it's not listed. You can just about see where they packed it up.
Running a level from the oak lipping to the back wall also reveals that the floor sags from front to back by about 4".
And yes, that is the mains water pipe you can see. The thought of trying to pack out the underside of the new flooring is now a no-no.
Plan B.
Remove a large chunk of the original coffin boards. There is an old oak beam roughly where the extension reel is. Two smaller oak beams at the right hand end of the water pipe and fortunately another beam underneath the packing on the right.
Then take some 4x2 or similar and coach bolt it to the oak beams to give me a level-ish set of bearers. Judiciously drop the floor level as it goes into the bathroom as I don't want to have to mess around with that soil pipe.
Re-lay new oak flooring onto new bearers. Assume that the study will go the same way. That's the theory.
Questions -
1) Is there a better way?
2) I don't have a secret nailer. The bathroom is very small, as you can see. The study is not much larger. My oak boards are 180mmwide so it won't take me long to reach the wall where the nailer can't be used. So it seems a bit of a hassle to buy or hire one for just a few boards. I'm reluctant to use screw-and-plug and was thinking about gluing to the bearers. Good idea or duff?
Roger
Plan B.
Questions -
Roger
