EdK
Hi,
Been trying to work out a basic set of tools to start buying.
I'm keen to buy once in an effort to buy wisely first time round and avoid the spiral of upgrading.
I am keen to buy some saws and some planes now (think I have the chisels sussed).
Saws
I was looking online and in various catalogues and it seems that the easy to get hold of and often named saws seem to be either Lee & Roberts or Lie-Nielsen.
The dorchester LR ones seem good as do the LN ones.
Is there much difference between the LR and LN ones?
The LN ones come in more variation and I am not sure which sizes to get if I went down that route.
I am 6'2" if that has any bearing on the size of saw you get. I notice that the LN dovetail saw is 9". The LN tenon come in either 12" or 14" I think.
And cross cut or rip...
From what I understand from reading a few books dovetail are traditionally rip teeth and tenon cross cut.
THen there is a set of all three (9" dovetail/12" cross/12" rip tenons). Is this a good place to start or is it overkill?
Or move up to a 14" tenon?
And the 'small crosscut saw' and 'carcass saw' on CHT (classhandtools) - are these needed ?
Any advice on which saws to buy?
Keen to be able to maintain them too. Any recommendations on saw files? One for all saws or do you need to select/size a file for the saw?
Planes
I have a LN block plane (nice little bronze 102 or 103 I think - low angle one from last years splurge). and am keen to start buying more planes.
Was looking at LN and Veritas.
I've read a bit and am keen to buy a couple of planes.
I've been looking at a smoother and a jointer.
For the smoother I was thinking about an LN 4 but then read that David C. tunes his LN 5 1/2 as a smoother. So I am unsure about this choice of mine !
Initially I was thinking LN4 - LN6 - LN7 (yes, and rob a bank)
Later I was planning on getting a shoulder plane (LN 042 maybe ?)
Or am I better off getting a smoother, a jointer and a shoulder plane and looking for a doer-uper fore plane?
What is a good configuration to start with?
I'll worry about funding this later... just trying to get to an ideal starting point.
Cheers Ed
Saws
Planes
Cheers Ed
