Bar Stool(s)
woodbloke66
17 Sep 2018
Salisbury
Bar stools in ash, finished with a couple of coats of Osmo Raw with wax over the top, 18/8 stainless steel footrests fitted, screwed in place with A4 Torx head screws:
Based on an original design by Oscar Pipson from new Zealand, using doweled construction - Rob
    273.7 KB
    254.9 KB
    246.9 KB
    244.6 KB
    249.5 KB
    242.4 KB
    237.3 KB
    223.7 KB
Nice work. Well executed. This type of stool usually has a hard life. These look like they will stand up to it.
phil.p":2x9ivs78 said:
Nice thin bar for scraping the mud off your boots. :D
The original design didn't have them fitted, but as they're going up to London to be installed in my son's flat, he wanted footie rests. C'est la guerre - Rob
marcros":18tbsad9 said:
did you use the arbourtek on these Rob?
Nope, initial shaping on the seat(s) was done with an Ax tc cutter in the angle grinder. Effective but very fierce! - Rob
Very nice! How are the legs connected to the seat?
Sent from my SM-G977B using Tapatalk
Each corner has a 150mm, 12mm dia steel dowel epoxied in place; they're going nowhere :D - Rob
Your a very talented woodbloke woodbloke, everything I've seen you post looks top notch to my eye =D>
Many thanks, much appreciated, but with this particular job I never want to see another bit of sandpaper again. Ever - Rob
