Hi Guys, I am having some real trouble with my bandsaw, a Scheppach Basato 4. Now, it seemed to be working fine, before and I have not changed anything, except swapped a blade. Now, I cant get it to cut straight, it drifts. I have Steve Maskery's excellent bandsaw DVD and have spent the last 4 hours swapping blades, checking table and fence alignments, position of the blade on the wheels, , all as per his recommendations. It will cut straight if I use a small piece, but anything over 2 inches high, it drifts and I cant think what else to try. The one thing I did see is the bottom wheel adjustment wont go as far as the top one, I cant adjust it any more, it is right up against the side of the housing. I am talking about where the blade sits on the wheel, forward and it will track left, and back it tracks right, correct? What is the important section of the blade to get centered, the teeth, or the middle of the blade? Obviously with a wide blade, if you put the center of the blade in the middle of the wheel, the teeth will be quite near the front. Well my problem is the with the fence to the left of the blade,the blade starts tracking left, IE narrowing the cut on the workpiece and forcing the blade over. This then makes it cut out of true vertically. So, despite max adjustment on the bottom wheel, it still tracks left, leaving the position of the blades different on the two wheels, what can I do?
Cheers, Mark
Cheers, Mark
