Ttrees
Iroko loco!
Hello folks
Bit of a head scratching moment.
Hopefully this will be the end of my Centaurolization attempt on my old Italian bandsaw.
After tracking down the cause of upper wheel wobble to this, it seems I need to address the spacer issue I'm having.
This is the rear of the wheel, and that bearing has some space to wander until it butts against the retaining clip.
A clue might have been that the bolt never cinched down on the washer holding the wheel/bearing in place.
As in the inner race was free to move about, and the washer does not have any say in the matter.
Noting that the Centauro's of old, have a big washer which looks to capture both races of the wheel, I wonder what kind of spacer is in those wheels.
That is.. if those wheels have a non shouldered bore?
If so, I question if things are still the same with new machines made today, using a non shouldered bore...
Is there a better way of doing things, as that orange spacer seemingly isn't up to the job.
Some Centauro machines of old have washers that seemingly might compress or at least align with both inner and outer race,
with possible a thou more contact with the inner race?
Compared to my machine where the washer which would only have contact with the inner race...if the spacer was wider, that is.
Looking at Jack Forsberg's videos earlier of work done to the Poitras (non shouldered bore) spacers and bearings.
I couldn't find recent activity on his local forum to question him about it.
Here is a look at the bore
I'll skip to the more important aspect of the spacers which Jack covers
I see a cast hub with a raised ring to press against the outer race,
Seems he has two spacers made of cast iron and the inner spacer is a thou wider.
I wonder what would be the best solution for me, as I don't see any wear on this orange plastic/rubber spacer,
and I guess things could be improved.
Love to hear some suggestions, especially anyone who possibly might have worked on Centauro's which possibly has a better system,
as I've not read anything about this before, nor can I find anything but Jack's posts on the subject.
Tom
Tom
