Hi,
so back in 2019 I bought a second hand Jet 16" bandsaw, which after some tweaking performed ok for about 6 months - then the electrics cut out, which turned out to be a burned out motor.
So after asking around, found a locla supplier who 'rewound' the motor, (£185), which got me up and running again.
What with Covid and everything else, didnt use the machine much until this year, and having spent some time fettling it so it was cutting straight, and was all set up, was getting some use out of it - then disaster struck - the motor burned out again.
So i called the company who re wound it before, but they are snowed under with work and cannot touch it, so went searching for a replacement.
so its a single phase, 4 pole, 1.5hp motor, with a 19mm shaft and face mount - pretty straightforward you would think ?, absolutely not !
so far replacement motors are being quoted at roughly £700, finding someone to re-wind it (again) - £450.
I know a 'new bandsaw is anywhere between £1300 - £2000 depending on make, model, but thats the ballpark for something comparable.
Have spent what feels like forever emailing sompanies to find a replacement, or someone who can rewind the motor, and the majority just dont even reply, so now beginning to wonder - do i need this, is it worth the time and effort.
Frustrated as hell !
