Alexam
Bandsaw Boxmaker
pops92, just seen your question on this. The first boxes I made were finished with sanding sealer and mycrocrystaline wax polish http://www.axminster.co.uk/chestnut-mic ... wax-951143. After sanding down through the grades to 320, I applied a coat of sanding sealer, allowed that to dry and then sanded again, but only with softer pressure. A second coat of sealer and then after sanding with 400 grit to get rid of the 'bits' and a couple more coats of the wax polish. I made quite a few boxes like this.
Then I looked at Tru Oil and found that a higher polished finish was easier, although the Tru Oil is rather expensive. I usually get the 3 oz bottles, but dont remove the aluminum seal, just use a tooth pick to make a small hole in the centre, which you can tape when finished before putting the cap on. A few drops go a long way, but sealing it up after each use keeps it going longer.
After sanding to 320. give a coat of sanding sealer first and allow to dry, then lightly sand again to 400 and use the tru-Oil, Be generious putting the first coat on and allow to dry partly for the first 5-10 mins, then gently rub off wth a lint free cloth. Allow to dry and gently sand with 400, then more Tru Oil with a cloth, rubbing it gently off and allowing to dry. Further coats will improve the final finish and it depends how glossy or satin you want it to look.
Tru-Oil can be used without the sanding sealer and will be absorbed in more depth but take longer to dry out. More coats are used when no sanding sealer has been used, so you need to try it out, perhaps on some wood that you have used for the box.
An essential part of the process and a rule, is to photograph the final job and put the photo on this site.
Malcolm
PS if you or anyone thinks I can help with anything, please PM me and I'll do what I can. If you are near enough, pop in, but call me first. Phone number on my web site.
Malcolm
