Sapper
I'm looking at perhaps getting the Record BS300E bandsaw. I've been told their blades are pretty useless, if so, what make of blade would you recommend?
If you are not doing a resaw on your bandsaw, go for a 1/4" one for tight curves,As a hobbyist and for general purpose use, which couple of their blades would you recommend I should start with?
Asking the obvious, why buy a blade that you cannot fully tension? My BS400 is supposed to do a 1 inch blade but it cannot tension them enough so I use the 3/4 supertuff premium which are apparently thinner so can be tensioned and I think this is the limit for the 400.I haven't used the 3/4-inch blade yet because I doubt the BS350 will be able to tension it properly.
