@sometimewoodworker
Regardless of what might suit ones work, I was just picking up that one should probably
have a very good idea of the machine, including disassembly of the table to use the beam.
Once one does that more than twice, I reckon they might likely choose to fix their "error"
as that is what it will seem like more so than if one were to adjust the fence instead.
The part where I may be talking junk is something like ....
If you haven't taken the table off, how do you know the machine is set up as good as it can be?....
Not saying there's not an easy way around this which hasn't been demonstrated,
but I have yet to see it.
This is relevant if one has a large hub in which the belt rides in,
Misalignment here, one could say a cattywompus effect is an understatement, so
my take on things is its possibly easy to end up with the same effect as the other S45
on ...."the place we can't mention here, 2"
in which it seems the hub is going to get machined for larger bearings!,
but even if that were not the case, seems easy to do the same with the motor too,
or just to knacker them enough to make them real scratchy.
Hopefully I'll get a wee part made within the next day or two and get to test out my
newly fettled machine....should I not find other issues, and get things done to my liking.
Pity I don't have any good narrow gauge blades to compare with my Axi ones,
what a difference in table adjustment I needed to make,
fair enough everything was all up in the air and serious work needing doing to the machine, so I can't say it that adjustment would be any different now.
That's a big question in my opinion, using differing blades of the same width,
and that's only to start with!.
It may change ones opinion whether that table or fence adjustment would be preferred.
Not that I think I'll be changing my ways,
I could just be here to sell you a bandsaw buddy!
All the best
Tom
