SVB
beech1948":37zo53vc said:Re above two messages. I agree that the guides are a bit too far back from the blade edges. Side guides should be just shy of the bottom of the blade gullet. If the rear guide is not close ( say 0.5mm or a bit less) from the rear edge of the blade then no real guidance is being achieved. Probably your first adjustment.
Honest John":37zo53vc said:My bandsaw will cut perfectly straight fence guided rips with no bearing support at all.
I’ve not adjusted the guides when this video was taken as I believe, as is said above, that the blade should run true and smooth without the guides when not in use. The guides are really just there to keep the blade on track when under load / cutting curves etc. The YT snoodgrass video shows the rear bearing just not making contact under no-load conditions so don’t think I should use this guide to hide the issue I have (even if I could which I’m not sure would work).
Simon
