Band Saw Drive Belt Tension
segovia
13 Aug 2009
Merseyside
I have my Metabo 317 stripped down and ready to re assemble as I was never satisfied with the set up from the factory. I am following Steve's advice form his video workshop essentials. However there is no reference that I can see to drive belt tension. What is the standard to setting drive belt tension ?
Regards
As I recall from SM's DVD, its a question of developing your musical ear and twanging the back of the blade until it sounds like a proper note. Works for me.
Brian
Edit: Ooops! I haven't woken up yet drive belt tension mmmmm? Steve??
A good rule of thumb for V belts is that you should be able to move the longest run by +/- 1/2" from its rest position.
For flat/poly vee belts you should be just able to twist the belt through 90 degrees on the longest run.
For drives with a very small pulley driving a much larger one, the contact with the small pulley can be down to 1/3 of the circumference and in these cases extra tension to prevent belt slip can be needed but ONLY if it slips
Excessive tension only leads to premature bearing failure.
hth
Bob
hth
Bob
Plus one.
I start off with it loose(ish) and gradually tighten it just enough to stop any slipping with the machine under load.
