FWIW I don't really use the "Snodgrass Method". I did watch his video a long time ago and found that I was doing something quite similar anyway regarding blade/wheel positioning.
My saw is an Axminster 250 something, the bottom wheel was out of whack with the top wheel when I got it due to there being a bit of slop on the arbor, the addition of a thin washer fixed this problem and now they line up well.
I almost exclusively use 1/4" blades and once I got things set up I almost never have to adjust the guides. I remove the old blade, put the new on, tension it up and then adjust the top wheel until the gullet is roughly centred on the wheel and at this point it is just about touching the guide bearings, I add a touch more tension and then lock it down. Blade change only takes a couple of minutes now since I cut a slot in my fence guide so I don't have to remove it anymore.
I also am not a tuffsaws fanboy as some will have noticed. They do not last as long for me as axminster blades but I am currently trialing them on a longer term basis as I think their lower cost might just make them better value for money overall, this is yet to be proven in my case though.
