The bamboo poles are split length ways , 6 sections are then hand planed on a steel planing form, which produces the desired taper. Then the 6 pieces are glued together. Varnished and rings and reel hardware fitted. As simple as that! The cork handles are turned on a lathe. I want to learn to turn some real wood for the real seat in the future.Looks cool. How did you make it?
I use a 3 weight Orvis Battenkill.Very nice indeed. What reel do you pair them with?
What sort of bamboo?The bamboo poles are split length ways , 6 sections are then hand planed on a steel planing form, which produces the desired taper. Then the 6 pieces are glued together. Varnished and rings and reel hardware fitted. As simple as that! The cork handles are turned on a lathe. I want to learn to turn some real wood for the real seat in the future.
It’s called Tonkin cane.What sort of bamboo?
That rod is a 3 weight and casts really well. A lot of older rods were very soft, i have a collection of old rods and there terrible use.What weight do they cast?
Most split cane rods I have used are a very soft action, are these?
I use a Waterworks Lamson on my Loomis two weight seems to balance well, the rod only weighs a couple of onzs, interested to see the process.
I know the thread is old, but it's the only reference I can find to the information I need, I am specifically talking about shaping cork handles, I have a need to convert some of my rods to double handed to ease my old aching bones, anyone have any advice?The bamboo poles are split length ways , 6 sections are then hand planed on a steel planing form, which produces the desired taper. Then the 6 pieces are glued together. Varnished and rings and reel hardware fitted. As simple as that! The cork handles are turned on a lathe. I want to learn to turn some real wood for the real seat in the future.
Irrc as it's over 30yrs since I did it with my dad, we would hollow out the cork segments until the were a tight fit on the blank, then sand them length ways before circular fashion using finer grades of sandpaper.I know the thread is old, but it's the only reference I can find to the information I need, I am specifically talking about shaping cork handles, I have a need to convert some of my rods to double handed to ease my old aching bones, anyone have any advice?
You used to be able to buy diy kits, might be worth a google searchThanks for the reply, I was thinking more of carving them to shape before sanding to make a flared butt section and curved handle, I suppose getting hold of some cork and trying different techniques is the way forward for me.
Post a photo of your existing handle Mike, especially the end of the handle you're looking to extend and see what ideas evolve. I used to make up my own fibreglass fly rods a great many moons ago, it's unlikely but not impossible I have some old components lurking around somewhere. BTW a good source of cork is a decent quality, thick, close grained bath mat, easy enough to cut the core and oversize outer with holesaws the if you have access to a lathe it's a doddle to shape or can even mock up a jig for a pillar or hand drill, it needs very little effort to sand cork to shape.Done that, but can't find a suitable bottom handle.
Have found a complete salmon rod handle, but that does require stripping off the existing handle, reel seat and first stripping ring.
Hi, just seen your comment, I glue cork rings to the desired length, colour or pattern, then these are sanded very easily on a lathe, if you don’t have a lathe you can rig up a drill. PM me, your location, I may be able to help.I know the thread is old, but it's the only reference I can find to the information I need, I am specifically talking about shaping cork handles, I have a need to convert some of my rods to double handed to ease my old aching bones, anyone have any advice?
