Bailey 4 1/2 Plane date advice ?
Blister
10 Nov 2006
Boston Lincs
Hi people
Trying to date this Bailey 4 1/2
It looks and feels old and I am hoping it 1902 :lol: :?:
It has Stanley on the lateral leaver , you can see the PAt numbers , also has brass tote top screw , Tote and front knob look like rosewood
Photos as follows , any questions please ask
    141.7 KB
    127.4 KB
    135.9 KB
    153.4 KB
    156.7 KB
    118.2 KB
    157.2 KB
    179.6 KB
    176.8 KB
    159.2 KB
Hi, Blister
Nearly time for a new blade :shock:
ac445ab":2g14c0e0 said:
Yes,
This plane was made between 1902 and 1907. It's a type 9.
Ciao,
Giuliano :D
Thank you Giuliano
I may have to keep this one original then , and use a later 4 1/2 to convert
I see you have a fine selection of hand plane's :p
Just watched some of your videos :mrgreen: very interesting , Thanks :lol:
Hi, Blister
Was it from House of Fraser :wink: :)
I've been thinking about doing good quality thin irons for a while now, this would seem an ideal situation where one would be applicable. You can add beef with a decent cap iron but would be able to render increasingly desirable antiques like this workable yet un-tinkered with.
Hmmmm.
matthewwh":aq42l28b said:
I've been thinking about doing good quality thin irons for a while now....
Great idea, but not too thin. My thickest Record iron is 2.4mm thick. 3mm thick irons require filing the mouths of fine mouthed planes. I wonder if something around 2.6mm might be a good compromise.
You can add beef with a decent cap iron ...
...while putting the original iron aside in case you want to sell the plane later.
And for thick irons, have you considered making a cap iron with vertical slits above and below the corners of the yoke slot, then the two tabs could be bent down a couple of millimetres to allow an unmodified yoke to engage the cap-iron - a variation on Mr Cosman's solution (there's always more than one way to skin a cat!)
Cheers, Vann.
Good idea Matthew.
It must be possible to make the 'standard' thickness 'Bailey' type iron, with good quality steel. But lack of thickness might be a problem if you were considering a laminated blade, like some of the blades found in the old woodies. Until thinner blades are available, it will remain necessary to file the body/mouth to fit some of the thicker replacements.
Here's hoping...
John :D
Hi, Van
I was thinking the same thing a while ago. I was going to make a new cap drill a hole each side of where the slot will be. and cut a slot between them. leaving lots to bend down. Never got round to it.
