This is a REAL disc sander that I found to extremely versatile in sanding both big and small stuff and which operates on a normal three pin plug. It can remove a lot of material quickly and effortlessly if needed. The table moves vertically and also tilts in both directions. There is a slot for mitre gauge and a port for a vacuum hose. The sanding disc is a bit ragged round the edges but I have a new, unused self adhesive 20" sheet to replace it.
This is a heavy piece of kit (close to 200kg) so collection only. I can lend a hand to load it but you will definitely need someone at the other end to help you unload it.£350
