I suggest using back bevels only on bevel-down plane blades. Bevelling or rounding the back of a bevel-up plane blade will cause a significant loss of clearance angle.
Hi Wiley
The ease with which we make our international visits makes it harder to know whom is the visitor and whom is the visitee! Nice to have you vocal.
DC has a lot to answer for regarding the use of "mini" backbevels on plane blades. This is my term - would that help separate our the angle-changing from the blade-straightening types? The fact is that there really has been little discusion about backbevels and their effect on BU planes. Perhaps it is time that our collective wisdom is used to write the book.
Let's take the angle-changing type first. A backbevel of 5-10 degrees on a bevel down blade is used when there is a desire to increase the effective cutting angle of the plane. This is a well-known, established method for BD planes.
Use this same degree of backbevel on a BU plane and you could be in trouble. From memory (never a good thing in my regard) the minimum clearance angle for a BU plane is 6 or 7 degrees. So, take 5 degrees (the backbevel) from 12 degrees (the bed angle) and you have 7 degrees. Ouch.
Now the mini-backbevel is a different kettle of fish. Using the "ruler Trick", it is only about 1 degree. It is not intended to alter the planing characteristics. Rather it is intended to clean up the back of the blade. It is an alternative to the hours that might go into flattening the back of a plane blade (since, as we all are aware, you ain't goin' to create a sharp edge unless it is a single edge).
A second use for DC's mini-backbevel (in my view) is that is does a better job of removing the wire edge from A2 blades than just rubbing the back of the blade back-and-forth on a waterstone (or your own favourite poison). The effects of a poorly removed wire edge can be heart breaking. So the use of a mini-back bevel on BU planes is quite desirable and is a separate matter from the issue of flatness, per se.
On a BD plane, a mini-backbevel is going to pose no problem at all. On a BU plane, a 1 degree bevel should have no effect whatsoever on the clearance factor.
The question remaining is what effect does the mini-backbevel have on the planing characteristics of a BU plane? I am not clear here. My logic says that it is similar to the effects of a backbevel on a BD blade, that is, it will increase the cutting angle by its amount. Still, I cannot see 1 degree making much of a difference. Can someone clarify this point? And, of course, comment on the others I make.
Regards from Perth
Derek
