Back bevel sharpening
Karl
2 Jul 2007
Workshop
Just thought i'd share this cunning little discovery with you all.
What you are looking at is a blade with two (yes, two) honing guides attached - one to each side of the blade.
First I attach the Eclipse style guide in its position to hone the "normal" microbevel. I then attach a second guide behind it, with the wheel operating on the opposite face. The two guides are then used alternately through the various grits of your chosen sharpening method to create a nice polished microbevel & back bevel. In my case this is Trend fine stone, green honing soap, white honing soap.
Here is the back bevel being created on the trend stone.
And being polished on the honing soap
The resultant microbevel
Result - a nice sharp edge!
Karl
Hi Paul - the second jig is a cheap Axminster jig i've had for a few years now. I haven't used it really - got the Eclipse instead. But its fine for this application - gives really good results.
Karl
Roger
I didn't actually "measure" the back bevel angle. I'd guess around 20-25 degrees, giving an EP of 65-70 degrees. Obviously the angle of this back bevel could be reduced by moving the second honing guide towards the rear of the blade. You can't go any higher (not that I think you'd need too) cos the first jig is in the way.
Forgot to mention the reason why I thought of this. I always prepare my bevel down blades with a small back bevel - approx 5 deg's. It's a variation on the "ruler trick". I do this simply using my fingers as a registration point for the various sharpening stages. But as this back bevel angle increases it is hard to maintain a constant angle, so I popped a spare jig on the back of the blade and Hey Presto!
Karl
lurker":f5n9fn92 said:
I've got one of those Ax guides - they are absolute rubbish!
But they clearly work in this application :wink: What's good is that you can register it off the Eclipse jig and thereby keep the roller square to the edge of the blade, or pop in a parallel-sided spacer if you need to set the roller further back from the edge.
I think Karl has hit on a brilliant idea with this one.
Cheers :wink:
Paul
I would not argue with that.
As you say, the eclipse keeps it square in this instance.
As a guide on its own the Ax will not keep a blade clamped true no matter how much you tighten the nuts.
Eclipse clones are about half the cost too.
Paul - you do flatter :oops:
Now, which mag offers the best prize for readers tips.... :lol:
Karl
Totally agree - I bought the eclipse about a week after the Axminster guide. Like you say, it is almost impossible to get a good square registration on the guide.
Mine sat on the shelf for a few years unused.
Karl
