Baby rattle -what finish ?
OldWood
1 Mar 2005
Edinburgh
There's been a rush locally in baby production in my daughter's generation, including our first grandchild, so rattle making is the order of the day - quite good to find something to make a number of to hone up on the tool technique.
I've seen that 'vegetable oil' is the recommended finish - is this any vegetable oil or is there a preferred one?
Rob
I'd recommend plain Liquid Paraffin ---ether the light (thinner) version in Chestnuts Food Safe Oil or the thicker BP version from chemists---if you want to give them some measure of moisture resistance, just in case there is a reaction component blended into whatever cooking oil you might choose.
I would also second the notion of plain paraffin oil - Chestnuts Food Safe being the one I know, as it is essentially inert.
On a second note, (and due to the arrival 15weeks ago of my son), could you give me an idea how to make a rattle, as I would love to make one. My turning skills are rather limited to a few bowls, but am up for a challenge (maybe!).
Cheers,
Adam
There are a wide range of finishes that are "Child Safe" but, just to be on the safe side, I will be using Chestnut Food Safe Finish for the ones I plan to make for my iminant arrival....
Richard
Hi guys
Adam - try this for guidance if this is the type of rattle you're after
http://www.torbaywoodturners.co.uk/rattle.htm
biggest problem I've found is turning the walls too thin. My third attempt (done following these instructions, though I preferred to use a gouge rather than the Forstner bits) looks good and rattles fine but will be given a nice finish and condemned to be 'look-see' only as I suspect it will break up if abused. Small bits of gravel make a better sound than beans I've found.
Out of interest - as a survey !! - do babies prefer the rattle or the handle with rings on it ?
Thanks for your guidance everyone.
Rob
One thing to watch if you are doing rings, either make them a good fit on the stem so little fingers can't get under them or large enough to give clearance on small fingers.
I've had the pleasure of trying to calm a young mum down whilst trying to split a ring to get a set of pretty little pink fingers out of a jamb. (not one of my creations thank goodness -- rattle or baby, before you ask :lol: )
Rob / John,
Thanks for the info - I think perhaps the captive rings are a little beyond my abilities as of right now.... :)
However, I may just give the other sort a shot.
You mention thin-ness of walls being a problem - what wood do you think might be best for transmitting the sound? I imagine something hard would work better than soft?
Cheers,
Adam
I use a home-made mix of beeswax and carnauba wax.
Whatever finish is applied the rattle will be stuck in the mouth and the finish will likely deteriorate.
Does this happen to the same extent with Chestnut Finishing Oil/liquid paraffin?
frugal":568p014d said:
Would anything classed as Toy Safe be sufficient (I am thinking Chestnut Hard Wax Oil) or would it have to be food safe?
Chestnut Hard Wax Oil is safe to use on toys to quote there bumf "Complies with EN-71 making it safe for use on toys"
I belive all Chestnut finishes are to this spec but if not sure there website gives the details.
john
So many babies being born! Congratulations to all concerned!
To be regarded as toy/child safe (the phrases are pretty much interchangeable) a coating has to comply with part 3 of the EN-71 regulation. You can read more about the test here.
We have had many of our products independently tested to this regulation and they have passed, which means they can be safely used on toys and nursery furniture and other items which a child could suck, chew, lick etc and they will suffer no ill effects.
We haven't tested all of our products - for example Lemon Oil and Friction Polish and although we are confident they would pass, to label them as toy safe would imply that we also think they are suitable (ie hardwearing enough) for toys, which we don't feel to be the case.
Curiously, we haven't tested the Food Safe Finish for this very reason; whilst it would almost certainly pass, we can't recommend it for use on toys! The other products have been tested and would, in our opinion, make a better job of protecting the item.
As far as I am aware, the test for food safety is different to that for toy safety; the former checks for more elements and I believe the limits are lower too.
I hope that helps.
Terry - many thanks for that. I'd forgotten you contribute to these pages and have used your company website Contact facility to ask this question, so no doubt the answer will be the same.
However ..... your post is helpful in that it says what is NOT suitable (though Safe or Probably Safe !) due to lack of tolerance to slavering lips, so would your Hard Wax Oil finish but more capable in this application - or perhaps something else.
Perhaps we could do some trails to see which is the best :D :D :D. I've got at least four to make and there does seem to be some others here with the same project in mind.
Rob
Hi Rob
I'm glad you found my answer helpful, I've been giving this some thought since my earlier post...
I think I'd opt for one of our 'softer' finishes for a rattle, such as Shellac Sanding Sealer and WoodWax 22 or Hard Wax Oil or Finishing Oil.
My reasoning is that these finishes are flexible enough to 'give' slightly if bitten (or gummed!) on. It's not that I'm worried about the other coatings chipping off (that really shouldn't happen under these circumstances) but a flexible coating should be longer lasting and shouldn't harm tender gums.
Hard Wax Oil would be a good option.
Buff with Canauba wax should be pretty good at resisting the gumming and it's regularly used to coat fruit and veg to reduce moisture loss.
But if time was available for surface to dry I'd tend to give items a safe oil soak first to add a bit of depth to the wet resistance. Do you see any bonding problems with wax over oil Terry, I've never encountered any once the oil has surface dried/cured.
We have just had a friend give birth and I have a yen to give them a gift, and I have a can of hard wax oil. It almost seems like it was meant to be ;) All I need to do now is get it done before he gets old enough to turn his own toys ;)
Jammy little sod was born on sunday evening at ten past eleven. Or 10:10GMT on 10/10/10. No one ever has an excuse to forget his birthday.
Terry
Many thanks for your second answer - I see there's a request for yet another contribution from you. It looks as if this gives me an excuse for a tin of your Hard Wax Oil.
I must admit that when I started this thread I had no idea it would show up even more people facing father / grandfatherhood. Someone did say recently that there was a spike in the birthrate this year, and certainly my daughter has a large collection of people she knows who are on the baby production route.
Rob
Rather slightly off-topic, but if you plot birth-rates over the course of a year, there is always a peak around september/october. Something to do with Christmas fun being about 9months beforehand, give or take a week or two...
Cheers,
Adam
That's in interesting one Chas; technically it shouldn't work, but it does. I've done it for years and others have done it for even longer with no problems at all.
