Inspector
Nyuck, Nyuck, Nyuck!
Aww it is not the square that is out, the rule is tapered. :wink:
Inspector":67br8p89 said:Aww it is not the square that is out, the rule is tapered. :wink:
Doug71":18f8akob said:Get yourself a magic square and all your problems will be solved
https://www.youtube.com/watch?v=dB0MBGiX8TQ
Eric The Viking":w0kx5zfr said:Inspector":w0kx5zfr said:Aww it is not the square that is out, the rule is tapered. :wink:
I bought a couple of Bahco 300mm adjustable squares recently, after "several people" suggested they might be good value.
No, they're not square (by my book not close either). Gentle attempts to fettle them by filing the nibs in the stock failed. At this point I noticed the rules, when put up against each other, show a lot of light in the middle using two of the edges, and a lot at the ends using the other pair of edges.
Yup, they're curved.
Now I have decent wet+dry in various grades, and a glass plate, and a proper Axminster straightedge (which is straight, enough for woodwork, anyway). I can take the curves out, probably, but can I get the sides parallel using manual techniques? Not so sure.
Serves me right, I guess. I can still use them for distance setting, rough distance setting, I mean...
PS: don't get me started on the not-adjustable level bubbles in the stocks. One is passable, the other is quite ludicrously off - never checked in production for sure. Why do they even bother? Bahco, put the cost towards buying some straightedges for the rule production line, and make sure they get used...
adidat":3fxck6za said:Yeah but how does that help you if you need to mark a square line and theres only 60mm of available space?
Adidat
Yup, I had that thought too.Pete Maddex":3bfuaqyv said:I have just checked mine, I bought another 400mm one to use the rule in a Chesterman protractor head I was given, and they are both straight, it must be the luck of the draw whether you get a good one.
sunnybob":2bkk94oe said:Lifted direct from wiki;
Starrett employs about 2,000 people worldwide and the company claims to be the last remaining full-line precision tool company to be manufacturing their products within the United States.[1] However, much of the firm's manufacturing takes place at facilities in the People's Republic of China, Brazil, Germany, and the UK, with 28% of Starrett's worldwide sales being in Brazil in 2013.[2][3]
No point being obsessive about a name anymore. :roll:
